@ssaner or @Christian Can correct me if it is something I don’t know about.
We have not supplied any copyrighted material that I know of. MakeICT ( @JeremiahB or @paul.maseberg) acquired the rights to a limited reproduction of the Keeper for sale, but I would think that does not extend to members.
@kim should have the Kansas State border. She was making a lot of Kansas based art on the laser.
Inkscape is a good tool to convert images to SVG. Then cut it on many of our devices.
Tom,
That butterfly looks pretty slick. I had to check but I did indeed take the
CNC Plasma class in Jan '18. I’ve also taken the laser cutter class. The
problem I have with both of them is that I didn’t apply the knowledge after
the class so other than the general idea of each I didn’t retain much. With
the computer side of each being my weakness I’m having a hard time getting
started.
Your recommendation seems to be to make this a laser cutter project first.
I’m fine with that.
Do you think hardboard would be the best material for the laser?
I’ve also researched the necessary consumables for the plasma cutter. They
seem reasonably priced on Amazon. Between the shield, nozzle and
electrode do thry typically wear at the same rate?
I just ask about the class, so you can do it later on your own. I have no problem being on hand. I enjoy seeing other peoples project. If you think you will be ready this weekend I should be able to come down the space for a few hours to work on some things.
I have to admit, I have not used the new software on the laser, so I will need to have a refresher from someone. I don’t know that I have seen any quick refreshers on the calendar. (I have not looked)
For testing I would say the hardboard meets the correct price for testing $0.
It should not mater where you buy the consumables. If you want them same day you can get the from several of the welding supply houses in town, but amazon should be fine. I would have to look for my receipt.
I have a vectrix electric motorcycle that needs a new battery. Vectrix has gone bankrupt, so I have to make my own battery bank and use the old battery’s electronics and connections. I am not an electrician, but I can get the old battery out of the motorcycle. Because of the high voltage involved I’m afraid of working on the battery by myself
Tom,
My schedule is pretty flexible. Let me know what works for you this
weekend, afternoon or evenings would probably be better for me.
What do you need me to show up with? I’m guessing that having some 3/16
hardboard cur to size would be a plus. If we only get as far as a test part
off of the laser cutter I’d consider that a reasonable victory for the time
being. That would allow a break for whatever analysis in needed after that
part is cut and I can take an inventory of the consumables status and order
if necessary.
Depending on everyone’s schedule feel free to jump in the loop. I’d be glad
to help you if I make it down there. Your project seems pretty
straight forward and I think you’ll be happy with the result.
I am planning to be at the space a few hours before the member meeting maybe 12-3:30 then to to the quarterly meeting at 4-6 at the new campus. I still need to go over the new software for the laser. I found @kim wonderful document about the new software, so i don’t think it will be a problem, but it might be best to dedicate some time with you on Sunday. I have put a reservation on the Calender Sunday 2-3:30. Will that work for @AaronD?
@Malissa
I would be happy to cut the pattern for you. Is the white are where steel is left, and dark area is where it is removed? I am not sure if this is the pattern or resulting dyed print?
It is missing dimensions. If you could upload anything text description or picture of hand drawn picture. I not take any effort to create a pattern. I would be happy to sit down and give you a hand with Fusion 360. I like it for anything that has dimensions over inkscape. I have also done some 2d work with LibreCAD. They both fall in the $0 free area.
I have had some Fusion 360 lessons. This is simple enough that I can practice. I need to find one of the ones I already have. I will be at the meeting tomorrow and at the space Sunday. I’m in no rush this has been on my mind for a few months.
@Malissa
I just wanted to give you the opportunity to have something cut soon, while I am helping Arron cut something plasma cutter. It is just as easy as putting more pieces on the table and hitting a button.
No rush, I don’t know if you want to have the fish or learn to fish. If you are busy, and a very low priority I understand.
A fishing class is doable. We have a creek with fish in it right behind the new campus. I’m not sure I’d want to eat them, but catch and release works, too.
