I would like to do some tye-dying at the makerspace. I was planning on doing it outside cause bleach will be involved (on the concrete, not the grass) but I wanted to check in and make sure that was the best space.
If bleach is involved it called discharge dying and chlorine bleach is not the best or safest option for the grass or you garments. Even when washed out the PH of the cotton garment has changed and the fibers continue to rot, taking years from the life of the garment. Dharma Trading company has Discharge paste that are peroxide based and good for cotton. I have made my own solution using Ritz Color remover, another peroxide bleach, and hot water to help dissolve it, forewarning it stinks. I don’t know anyone who currently sells the Ritz Color remover locally but I do have some available. I have garments over 10 years old that I’ve discharged this way.
What are your server aprons made of? I bet 100% polyester or a blend of polyester? If that’s the case they will not work well. Polyester isn’t dyed it’s a form of plastic. Color is added to the pellets before they are extruder into fiber. It most likely will not work at all.
We can try it but the results will likely not be very good. I will be there Sunday to cut out some stuff on the laser. I will try my best to remember to bring the Ritz Color Remover that I have.
Here’s 2 examples of what I’ve done. Both used a spray bottle and I sprayed more in some areas, less in others and probably spilled it on in some places.
This one was rust dyed and then discharged along the bottom
This one was discharged then I used Fluid Golden Acrylics mixed with water to give it a stary night effect. The colors were not picked up well by the camera.
Yes, and you can cut a piece of butcher paper 8.5x11 and print directly on fabric with a laser copier. Best for outlines of embrodery work and light colors of fabric.
@malissa I’ve also heard it called “reverse dying”. Yours are beautiful!
@noahjwc I have dyed many things, aprons included, and Malissa is right. 100% cotton or natural fiber is best. Although a poly/cotton blend can give you a neat, almost “heathered” look where the white resists the dye.
The chemistry behind tie dye always fascinates me. If done correctly, your colors will become permanently bonded to the fibers. And as Malissa said, I also recommend Dharma trading if you want more info on processes.
@Noahjwc I don’t know how many you’re planning to do, but if it’s only a dozen or so I’d be happy to lend you some of my squeeze bottles, etc. I use a lot of dharmas fiber reactive dyes and love bright colors! I’ll send some pics in a few.
