LARGE Resin Print: Samurai with Portal Base
I’m about to begin printing Tenjin - The Cursed Scholar from Black Forge Games along with the Portal Base.
I’ll be using my two new Phrozen Sonic Mega 8K large-format resin printers which arrived today. These things are just rediculously MASSIVE.
To give you an idea of just how big the build volume is… here is a printed and assembled model.
I’ll probably do a 100% scale version until I know the resin profile I’m using works well. Then it’s time to GO BIG OR GO HOME!
OMFUG!
Summary
This text will be hidden
That is a metric ton of resin if its not hollow.
I didn’t think the density of resin was that high
Gheesh… That will be an impressive print…
I could almost see that turning into a play house for a spoiled toddler.
Its all relative. Just like how FDM printers have different filament that have different properties they have some resins that are fairly dense. Saw a guy try to make steel infused resin but he couldn’t get the steel powder to stay suspended in the resin without making the resin like silly putty.
Brad is trying to be king of 3D printing :slight_smile:
I resemble that remark! I’m hoping that the machines can be useful to help others get projects done that they otherwise wouldn’t be able to.
I am really jealous. I’d really like to see these printers. And I’d like to learn what your doing that you need TWO of them. :astonished:
I was worried that if I only got one it would get lonely.
I actually have a comparably large Eleegoo Jupiter coming as well. :slight_smile: Let me know if there’s anything you need printed!
How crazy ruch are you @bradcozine ???
What happened to their reboot? I had all the old episodes on DVD when Tobias was little but haven’t been able to find them since we moved to Kansas.
Scrooge Mcduck is outlawed in Wichita because he has more money then the Koch brothers. They were secretly confiscated
You’re not asking the right questions… it’s “How crazy in debt are you putting yourself and what hole in your life are you trying to fill?”
Like that… but if he was skiing down a stack of 3D Printers.
I hope you find what your looking for bud!
Cool printers
Speaking of a “stack of 3D printers”… the first rack of a 3D print farm is almost complete.
First 100% scale print is almost finished!
Although the printer is pretty slow, the print bed size does make up for it. I was able to fit all the pieces on a single build plate. If the printer was twice as fast, but I had to print two plates, it would balance out.
