I had an odd issue show up while trying to do a vinyl cut. The issue was not with the cutter at all, but with the Uniconverter. I had a pretty simple SVG that was done in Inkscape that I’m attaching here.
I loaded it up in Inkscape on the FabLab Thinkstation computer and saved it has a .plt file. When I then went to cut that file it did something quite weird. The top half of the “N” character in the decal was extended way above the rest of the drawing.
I took a look at the .plt file and it is a pretty straight forward format with a bunch of x,y coordinates. I massaged the file a bit so that I could plot the coordinates with gnuplot. The resulting plot shows exactly what the cutter did.
plotbad.pdf (10.7 KB)
Looking at the coordinates, it became obvious that there are a series of points where the Y axis coordinate is way bigger than it should be. I compared with the other characters in the drawing and determined that for that section the Y coordinate was approximately 11184 (units?) too big. I subtracted that amount from each of them and then did another gnuplot. That looked more like what I wanted.
plotgood.pdf (11.2 KB)
I then cut this file and it turned out perfectly.
Anyone else experience something like this? Anyone know why it happens, or how to fix it.
When I get some time I might try to take a look at the Uniconverter and see if I can can figure out why it did what it did.
Steve
