Vinyl Cutter
Hello All, the vinyl cutter is not holding the blade. I’ve emailed Fablab, but wanted to let you know that it is down.
The blades have been replaced. The 2 small ones were both very dull, and one of the large blade holders had a small blade in it.
I’ve removed the control panel to try to fix one of the buttons, so the machine is down for maintenance again. The panel will be re-installed tomorrow evening with cleaner and hopefully properly functioning buttons. If the contact cleaner doesn’t do the trick we’ll order some replacements.
Christian, thank you very much.
