Vinyl cutter setup changed
I had to move some things around to prevent the Raspberry Pi that runs the vinyl cutter from being damaged, so the old interface (the CUT_NOW file on the desktop) is no longer available. It was kind of terrible anyways, so hopefully no one misses it too much. The new web interface is much easier to use, and doesn’t require transferring files via usb drive. Instructions are on the wiki page if you need them. The computer directly across from the vinyl cutter has a link on the desktop.
http://makeict.org/wiki/Graphtec_FC2200-90/EX#Run_the_file
graphtec.makeict.org:5000
Vinyl Cutter Software link (Only accessible on the makeict network)
