Do we have one? If not, suggestions on anything I can use that we do have?
Do you mean a saw that is good at cutting existing veneer? Or do you need to create veneer?
The laser cutter would make that first option easy. So would the bandsaw.
If you’re needing new veneer, I’d recommend using the table saw to shave off thin strips. (Strips should NOT be cut next to the fence, though.) Set the fence up so that your thin strip cuts on the left side of the blade, not between the blade and fence.
I took it to mean a flush cutting saw but I could be wrong.
I know about a year ago we got a veneer blade for the table saw.
