So, just in time for summer, someone has decided to damage almost all our window AC units.
Currently Electronics and Textiles are the only areas not effected. Any other areas if you run the AC instead of cool air you’ll receive a blast of hot air.
Our neighborhood officer has been contacted.
Currently working on repair plans to get things back up and running. As units are repaired we’ll try to keep this post updated.
Down ACs
-Woodshop
-Metalshop
-Screenprint
-Ceramics
-Room 4
Well I saw the a one word note on the ones in ceramics and assumed that someone just did not know how to reset the internal breakers in the power cords.
They seem to have worked normally for the last several hours after I turned them on.
Unfortunately, Ceramics ACs aren’t working normally.
They do appear to be working, but due to the damage, They are simply blowing room temperature air. (Which can feel cool and cool you off, just like a fan.)
Please do not run them in cooling mode as it could further damage them and prevent possible repair.
Slight clarification to the list:
Room 4 (Big room)/5 (lounge) wall unit (in room 4) works. The window units do not in room 4.
