Unlocked window 12-31-24
Room 3
easily opened from outside
I’ve suggested it before, but could we paint one side of the lever green and the other side orange to make it easier to tell that a window in unlocked? It’s hard enough getting people to even walk the building to look for open or unlocked windows and doors, let alone actually going into the room and looking at the windows. I know this wouldn’t solve all the world’s problems, but it’s a small step that might help a little. When I’ve suggested this in the past, I think we did what we do and the discussion went off the deep end with adding stuff for automatic detection of open windows. I’m certainly not opposed to that sorry if thing but maybe this would help.
I think we all pretty much agreed that the paint was a fine idea, and even beneficial if we wanted to put some “Smart” solution for verification. However, we couldn’t figure out how to get around the curtains. Given the problem generally is brought up in summer when the windows are being used more frequently, we couldn’t just take them down. If you have to go in and check anyway, people would still not do it.
I walk the exterior searching for unlocked windows. This one was locked yesterday when I checked.
On Tue, Dec 31, 2024, 12:01 Steve Owens via MakeICT Forum <noreply@talk.makeict.org> wrote:
| SteveO
December 31 |
Thanks for the reminder. I think you’re right - it’s the curtains that get in the way.
Maybe this was discussed before… Actually I think it was and was dismissed as a fire hazard, though I don’t see it as such. Can we lock all except 2 or 3 windows in each room, leaving only those 2 or 3 to be opened and hem the curtains for those window shorter to allow the lock to be seen?
Next time I’m at the store, I’ll look for some neon green and orange paint unless there are other colors that might be better. I know that some people are color blind but I don’t recall what colors overlap, if that’s a concern
Red and green are the most common color blindness (10% of men have it). Some are also green-brown, like my Dad.
Thanks. I am hoping orange and green are visible enough with the lights off to easily see one or the other. In the dark, I’m afraid neon green and yellow might look the same
I’ve gotten busy with work travel again. I did do some searching at home stores for neon paint and it looks like they only carry aerosol. I haven’t looked elsewhere. It’s been my experience with bright colors like that that they require a white base coat, so maybe just some bright colors instead of neon would be better.
I saw it mentioned in a thread a year or two ago. Maybe not “disabling” windows such as screwing them shut because code, but a mention of “do not open” seal stickers might be enough to stop most from opening, be easier to check and maybe still pass code for any fire? Idk, it’s another log of food for thought on the fire.
I’ve been a member for awhile, and I always have managed to slip out (not being the last to leave ever) without having to walk, check windows, and alarm the building, but glad they shared to do that in orientation so I know to keep track of time and only go to MakeICT in the daytime :joy: thanks for thinking of a solution aside from electronics and taking time to try to implement!
