Just a quick update: Oxy/Propane is still not an option for fuel but thanks to Ted we have an oxy/act set up with TWO torches ready to go.
Awesome!
Not 100% sure, but I Believe those need to be secured. Knocking over the O2 can break the regulator and create a projectile. Knocking over the acetylene is arguably worse.
Ill see if i can’t find some scrap metal and weld up a caddie for them.
A chain across them should suffice. You can even attach it to the wood they are sitting next to
