Always wanted to try my hand at modeling, metal casting, and stone setting a tennis bracelet. My understanding is that they can be quite tricky to make because a good tennis bracelet is semi-rigid laterally with just enough flex to be comfortable. Not to mention that assembly is fiddly and the cleanup work repetitive.
Modeled in Rhino3D/MatrixGold today.
NEXT STEP: Printing a few test links in a wax-based resin for casting.
SECOND test casting in silver before moving on to 14K Gold. Had to make the hinges 50% larger than I originally modeled them for strength.
Now to cast a whole bunch of links… also have to do variations that will be for the start and end link, as well as some with earring backs and pendant jump rings. Yikes!
I’ve been paying CLOSE attention to your Jewelry Journey Brad, and I’m impressed with your progress. I really like what I’ve been seeing. Keep it up!!!
Are you making your jewelry at makeict? I didn’t think we did casting. Casting is what I’m interested in most, I would of hit that department up long time ago If I knew
