Small bandsaw fixed - 2025-12-14
I’ve been notified that the small bandsaw has a problem but I haven’t been by to look at it yet. I’ll do that this evening and will update the status at that time.
ETA: from what I can tell, the only problem with the bandsaw is the blade is dull so I will replace it. If there’s some other issue that somebody knows about, please describe it.
The saw seems to be fine now. The blade was dull. However somebody had also adjusted the tension far higher than appropriate for the blade that was on it and the tracking was badly misadjusted.
If you don’t now how to adjust machines, please do not adjust them. Let somebody know that there is an issue so that it can be dealt with correctly.
