Looks like the shotbot is in need of on expert to fix it. It is giving a “joint 2 on limit switch error”. I’d looked at all the switch and not see anything.
I checked it out. The z axis limit switch was stuck in the closed position. I adjusted it and everything seem to be working.
Thanks
That means that you’ve bumped into the edge of the cutting area. You need to click the little “override” box, then power on the gantry with the orange power button at the top. Then move the gantry back into the safe cutting area. Hope that helps.
On Tue, May 2, 2023 at 4:12 PM Stephen D Wagner II via MakeICT Forum <noreply@talk.makeict.org> wrote:
| Wag MakeICT Member
May 2 |
