i’m cutting out three triangles, I’ll try to attach a screen shot from easel of the project layout for reference. in my inkscape file and in easel the points look great. we did a test cut on osb and it rounded off the tip of the middle triangle and 5 of the corners on the base of the triangles. thought it was odd but it was small enough to not worry about. I checked the image and upped the speed just a bit. Second one we cut it rounded the same corners but earlier in the cut. on the left side of the pic the blue pin is the first cut the red pin is the second cut. Any Ideas on What might cause this?
Other info : bit size is 1/8 and was set to 1/8 at the time of the cut
three passes to do a full cut all three passes fallowed the same curve.
