Hey Laser folks,
I had a problem with Luigi today. When I pressed start it said something to the effect of “Problem loading file”
Can anyone tell me what that was?
(I fixed the problem by doing everything at once and throwing scientific reasoning out the window. I turned the machine on and off, rebooted the computer, copy pasted my parts into a new lightburn file and deleted a few files off of the machine.)
I have that problem when I pause then try to restart using the play button:arrow_forward: instead of the pause button:pause_button:. I have figured out I can resume if i press pause again. if you press stop then play buttons it starts right back up from the beginning.
Ps all buttons on the lightburn app not on the actual laser.
That’s probably it, someone had left a sheet on Luigi that had been cut. Probably for a while, since I was there using Mario most of the morning and after lunch a bit on Friday without seeing anyone until @ledeana showed up.
