I’ve swapped in the 50a SSR and brought the oven up to temp for a few minutes and then turned off the oven with the switch. It seems like the new switch is working.
Also, there is an led on the new SSR that is on whenever the ssr is pushing power to the heating element. I’ve drilled a hole in the side of the electrical box cover to make it easier to see the light.
For the time being, the lock out tag out is off of the oven, but I highly recommend unplugging the oven when you are done cooking your powder coated parts for the day.
