I was trying to use the plasma table today and it would touch off, but them say arc not detected. The air was on. Any ideas on what is causing this and how to remedy it?
Did you check the consumables?
Yeah. I just bought a new fine cut tip and thought that might be the issue so i changed it out for the regular 45 amp, to no effect
To be clear, i switched all three components to the fine cut set up, and when it malfunctioned i switched back to the regular 45 components
Is the table grounded?
