Plasma cutter maint air filter
Someone said they were having trouble cutting some thick material (steel), and it was not cutting well. I don’t know the exact details, but what I can remember about the plasma cutter it should be able to cut through an impressive amount of steel.
There are many things that could be wrong, and I did not want to go over all of the details. I did check the air filter. When was the last time anyone change the air filter to the plasma cutter?
@josh.robinson Do you have a replacement filter? It seemed to be a bit soggy, and very colorful. It might be beyond the useful shelf life.
I believe that is simply a standard roll of TP
