Oxy propane torch jewelry lab
The Oxygen regulator is not working correctly for the jewelry lab torch.
Dean
If you can send a link for an appropriate replacement, I’ll order it or pick it up as needed.
Here is a link to a 30 psig Oxygen regulator for the Smith Little Torch
Smith Little Torch Oxygen regulator
Operating Pressures for the Little Torch range from 2 to 8 psi depending on the tip.
Note that an equivalent Oxygen regulator with the same range will work
Dean
Sorry for the late reply. I had hoped to catch you at the space.
The regulator you purchased is for a 1 lb.non-refillable oxygen cylinder. What I specked works with standard refillable oxygen bottles. We can use what we bought for special projects as that setup would be very portable…
