@Jesse @Robert @Mr.Bill were busy in the chilly wind this morning working on this beauty!!! Next weekend they expect to figure out the venting and an easy entrance so tomatoes can go into the ground early - today it was registering over 70 degrees in just a few minutes! And they STILL had time to try out Jesse’s new broadfork and help pull a LOT of weeds!
If you can find it cheap we use pipe for roll up sides and a vent at each end .
If someone can close it if frost is predicted then open in the morning, that is usually sufficient for the few weeks it will be covered.
If it were a sunny day? think inside a hot car but hotter. It’s more likely to be that way then not.
This is a great idea! I tried to make one out of 1 inch pvc the frame did fine but the plastic did not last one season i learned that not all plastics are equal and greenhouse plastic is made for this
