Need help figuring out how to wire up an exhaust fan
I’ve mounted the exhaust fan in the first image but there are 3 electrical cables hanging out: yellow, black, and white.
In the second image are the instructions in the manual.
I have to admit I don’t know how to interpret most of what is in the diagrams, or at least I dont know what to buy at the hardware store to wire up how the instructions say or just wire up something I can plug into an outlet and get the exhaust fan turned on and working.
Looks like you need wire nuts. No not david springs… lil screw thingies that look like a glue bottle cap. They will ask what gauge just say “wall wire” or snap a pic next to a banana for scale.
Wiring this into a house you may want an electrician. Wiring it into a plug the black (hot) goes on the right. The natural (but don’t lick it) goes on the left and the yellow/green goes on the bottom.
Wiring into your house is the same. Black to black, white to white… green to whatever.
Hey, I resemble that remark, and I’m getting tired of your insulation.
wire nuts I got, I know that much at least. and what I just got at home depot is labeled as a tool replacement cord, does anyone know why I should not try to use that?
That’s what I would use!
and in fact I did use just that, and it worked perfectly. thank you very much for taking the time to reply as well as for the advice.
Well post all your process and pictures to what are you making!
THE THING DOES THE THING!
