Mario issues
FYI, Came in to use the rotary on Mario. Wouldn’t power up, the breaker was blown in the back. Reset and it started working. Hooked up rotary, tried to set the rotary to 288 steps and 1mm diameter. Would not read in mm, only inches. Tried several times after changing Lightburn main screen to metric and closing/opening lightburn. So set to .0393 inches per some Google math. Started the cut, rotary defaulted to 3.393 inches, so ruined project (yes, I should have double checked it). Could not get rotary setting into metric or .0393”, kept changing to 3.393” and saying it could not save settings.
Can’t load a video, still not working, rotary seems to be unusable right now.
Is Mario working for regular cutting? Does the rotary work on Luigi? I don’t know if the problems with the new version of lightburn on Mario have been resolved and I’m guessing that’s your issue.
