Mario is Down
Mario is not moving correctly in the y axis. It will move an inch or two and thing it has moved all of the bed.
I am not sure when I will have the time to look into this. If you look into it let me know and if I can i will meet you here.
Thanks,
Andy T
Fablab Lead
Do you know if anyone has checked to see if it is rotary mode. Sort of sounds like that behavior.
That’s weird it was fine for us Wednesday at class :frowning: I can’t make it out this weekend.
I might stop by to cut down a sheet of plywood later. I’ve not used rotary mode but if somebody tells me what to look for, I can check on it
There is a toggle in ā€˜Tools > Rotary Setup’.
I’d say 99% chance that this is the issue. Be aware that the machine has to be on in order to toggle rotary mode because it changes a setting on the controller.
This is a common issue. Never hurts to check the troubleshooting section on the wiki: https://wiki.makeict.org/wiki/Laser_Cutter#Troubleshooting_Guide
Someone left the ā€œRotary Enabledā€ before they shutdown. I’ve reset it and it’s working as normal.
Perfect. Thank yiou.
