MakeICT Sign and Monument
Consider the purpose of the sign and what message is needed to convey.
At minimal, MakeICT Makerspace.
Average Joe might see MakeICT, assume some type of startup manufacturer, or whatever. Not give it a second thought.
Some form of editable message and announcement section, would be beneficial. Digital or Manual.
Being budget conscious is going to be of course a prime factor.
A foundation would need to be poured. Rebar etc. The monument would be anchored to the foundation. Any electrical would also pass through the foundation. Lighted sign at minimum.
Im not opposed to altering the Logo so that Makerspace could be located under MakeICT, thus preserving the head location inside the wrench.
Altering the arrangement of the logo is not something I have approval to do though.
The cost of these materials and familiarity with manufacture of most of this isn’t something i have a ton of experience with.
Preventing toppling of the monument/sign has several very straightforward engineering solutions.
It’s not really any more difficult than any common single pole sign or a street light pole. (Or any free standing basketball goal, which is the most recent thing I created a concrete base for).
The buried base that’s not visible but is necessary might potentially be more weight than the above ground, visible monument but is a simple concrete pier, just to mention one possible solution.
[Edit added after seeing more replies:] Running electrical supply through a concrete block is generally discouraged, usually you’re better of running buried conduit to, then up along the side of a base rather than burdening future repairs with the likelihood of having to cut into the base to replace a break in the conduit or wires.
Have we got a budget and should we set up a Request for Proposals with a transparent process of how we’re going to determine what we will finally create? Let’s do this right.
At one point I know a local artists and MakeICT member, Hugo, had talked to me about building a camera obscura on the property. It would be great to have something that’s more than just a sign.
This is one that’s at WSU that he created
This will sound pretty challenging, but just give it some thought.
At orientation, I saw a problem that could be used to solve two problems.
The Boiler is taking up needed real estate and MakeICT needs an iconic sign structure.
I know we can figure a way to dismantle the Boiler, get it out of the lower level, then repurpose or reassmble it for the sign.
It would be a major undertakig.
And before you poopoo the thought. Go down and look it over. It’s got a real steampunk look.
Neat idea, and while many here are good at repurposing stuff, that might not be the vision we, as a whole, want to project. That will be the real challenge in anything that isn’t just a sign - coming up with something that speaks to the side variety of things that makeict is too each member and prospective member.
Obviously I cannot speak for the vision of every member of MakeICT, I’m glad I’ve met their spokeman.
What is the Vision of the ā€œWholeā€?
I would like to meet them too.
When does that commitee get together? :sunglasses:
so where are we at on this?
We had a call for designs and there was a minimal response. We haven’t forgotten it though. Dean Day has proposed some ideas to Rustin. I can’t recall… do we have a group that is looking into this that is not the board?
Was this formal? When was the deadline? What was the spending limit? Expected finish size? Installation timeline? Artists need parameters and guidelines to know if a proposal is worth their time and effort. A forum post is not that.
Put it in the newsletter? I think more people probably read that than the forums. Have some mild guidelines with it?
There has been a lot going on lately, so this kind of fell in the cracks.
How does getting a group together in person Sun March 5th at 7pm to discuss the sign?
Copied from where I replied to the wrong thread. I will be in Philly then, sorry.
I never found time to put it in CAD, but my thought for a sign was the robot head with all the stuff above it as individual boxes of metal suspended above it, then a more traditional sign, maybe like those mentioned earlier, mounted on top. My only concern, and maybe it shouldn’t be, is that it would be pretty easy to climb on it. But it would look cool.
This is what I’m imagining as well but was thinking sheet metal flat pieces cut on the plasma cutter welded to metal poles and have the logo 3-sided on a triangle that you can’t climb and is boxed. The base would be made so it’s a triangle but high enough that we could one day add LED screens.
The meeting has been added to the calendar for 7pm Saturday in classroom 3.
has any further discussion been made on this?
The National Endowment for the Arts has funding in July that @Fundraising will be looking into. I think the current focus is the roof and the $40,000 we need to raise to cover that.
