M82 G code error question
Hey all,
Yesterday I was trying to upload my .ngc file to the shop bot software, but I was getting the error M82 on line 18. It was on at least two lines. Does anyone know why I got this and what it means?
What software did you use to generate the gcode? From what I can find M82 is not a valid code for LinuxCNC. It is used for 3D printers, though.
I used Easel
Can you post the gcode file? It also helps to have the exact error message.
I was using Easel, but I think I’m going to switch to Solidworks or Fusion 360. Would you guys happen to know where I can get the proper post processor files (ctl, lng) so I can process g code correctly in Solidworks/Fusion?
Update, got the files from Hawk Ridge Systems
