I noticed last night that the tailstock quill was not in the lathe. Disassembling revealed that the threads on both the male and female threads are galled badly. It’s a bad design, but cheap. I don’t know how expensive the parts are or if they are even available, but it seems a better solution would be to turn a brass or bronze insert to use with whatever new leadscrew is sourced or made.
We are haning trouble getting the parts, everywhere is out of stock or $200. John finally sourced some, but he may have gotten scammed. I really want to get it fixed, I thought about a helicoil but I think it is left hand threads. We could probably use some help
How important is the through hole in the leadscrew? Without that, it’s easier to make, but can still be done. The steel on steel design is a cheap choice used by jet.
The Quill in the Tail Stock has been in this condition four to 5five months. I called Jet and was quoted $75 for the parts and $110 for freight. (Weight less that 1 pound.)
I went looking for a Woodturning friend or acquaintance that could pick up the parts and put them in an $8.00 Priority Mail Box. Then I was notified the quill was out of stock and would be several months to get back in stock.
I have found a different source of Jet Parts for $90.00 and freight at $25. Those were ordered. After emailing about no delivery and no notice, I received an email 1 week ago that all parts except one were in stock. I wrote back asking them to cancel the 3.28 part and ship the remaining. I expect to hear soon on the shipping.
This lathe is one step above a beginners lathe in the Jet line. The lathe and bed extension retails for about $1,200. There are two higher grade lathes in the Jet line, priced between $2,000 - $4,000.
This one has been at the Maker Space since 2016. It was purchased and donated by RW (on the stand. That is Royce Wallace, one of the founding members an a Past President of South Kansas Wood Turners. He obviously made and donated a quality stand for it that will outlive the lathe.
Getting 6+ years from this level of lathe is pretty good, given the conditions of use in a shared machine shop as we live with in a Maker Space. The PCB, off on switch and the quill are the only things that have needed to be replaced.
John Nicholas
Asst Woodshop Lead Lathes
Yeah, I have no real interest in the history of the machine. Just pointing out that it could be fixed, but if you’ve ordered parts, good for you. I’ll leave it alone.
