Laser Ventilation Update
We added a control box for the laser cutter vent fans that will turn on both fans when either laser is turned on. This means that you will no longer have to turn on both machines, just the one that you want to use. The fans will turn off 5 seconds after both lasers are turned off.
If you notice any issues with the ventilation fans please contact fablab@makeict.org and leave a note on both machines. And of course, if for some reason the vent fans are not working properly do not run either laser cutter.
Thanks Christian. This seems almost foolproof.
