I will be doing an impromptu help session with crochet I plan to be in the textiles room possibly and hoping for Friday evening if not Saturday evening. And there is possibility I could be there tonight as well.
You will be able to come get help with anything if you need help stuck on a pattern and need interpretation, or are struggling with some aspect in particular, or need a very short refresher on things u forgotten, advice.
Cost will be $5 or donation if you end up getting my help for the majority of time for extensive time consuming help the whole time I’m there then I’m suggestion a larger than $5 donation would be appreciated as my time and mission are valuable❣️
all crochet that I do everywhere goes to pay for my son’s special needs monthly bills
I will be organizing the fabric in textiles and u can come and go for help from 6-8 at least-TBA
Please look for the actual class register to confirm room and time you may also show up and pay in envelope
So I will still be here tonight and be working in textiles room so even tho it may not be on calendar the same will apply tonight you can come and get crochet help from me tonight at 6 pm
I didn’t put it in because I started suffering from neck injury and a migraine yesterday
But I will be there tomorrow Saturday for the officially impromptu crochet help session 6-8:30 July 18th
If u need to text me to check before you come my # 316-573-2240
So I created the class for sat night but it is not showing on calendar. So anyone who sees this go ahead and come on in tonight or tmrw night 6 pm and I will be there you can simply use an envelope. I will work with you if u can’t p
It looks like you made a template, but didn’t get the class created… I am going to go ahead and create that class for you…
It should be on the calendar now… see if that looks right… if not, get with me and I will fix it.
Where is the correct place to go in to make a class
On Fri, Jul 18, 2025, 9:00 PM LaDeana Dockery via MakeICT Forum <noreply@talk.makeict.org> wrote:
| ladeana Classroom Management
July 19 |
