Would like to put a sink style drain on both sides does anyone have a tool that can make a flared/dimpled shape in stainless so the drain is recessed below waterline. Figured it was a long shot but if anyone does it would be here.
Simplist way is to make your own die set out of whatever thickness of metal that matches your flange depth. It can be as simple as a plasma cut hole in a piece of steel plate, and then you would sandwich your sheet metal between that and a round piece of plate slightly smaller than the hole before hammering the round plate down flush.
It’s a similar process to joggling flat sheet metal.
Yes plan to put a air tight tank below and drain after each use then apply pressure to tank to refill table when using. This is an attempt to reduce mess since I have made the base mobile
Ethan! YOU Just blew my mind that was a really cool video! I would have never considered 3d printing short run process tooling I need to research this more.
I have that same 20 ton press with air assist upgrade.
