Help Request for a Couple Projects
Hello,
I have a few projects I need/like to get done soon, but my time constraints are limited due to work and having a dear friend in the hospital getting treated for cancer.
Right now I have two projects I’d like help with:
  1. Adapter Plate for the Gammil Quilting Machine in Textiles
  2. Somewhat precision (using the term somewhat due to the beggars can’t be choosers clause) gauge blocks in millimeter increments that are roughly 1 3/16" x 1/2". The first one I need is a 6mm gauge block with broken edges so nothing sharp to scuff up the material its being used to gauge.
I can make and send AutoCAD files if needed, for the first project the measurements can be taken directly from the current plate that is in my possession; I can bring it and meet up with whoever wants to take on either of these projects.
Thank you in advance (and for getting this far in my post)
-Tarka
(Assistant Textiles Lead)
Do the gauge blocks have to be metal? If you’re not looking for the heft from metal I could probably 3d print something on my resin printer with very high accuracy, just very light.
