Exploration Place, MakeICT, and Wichita State University Foam Cutters
The Foam Cutter cuts 1/4" foam using Inkscape SVG patterns.
The current software has significant limitation and needs to be brought up to date
Runs on LINUX using Python 2.7 requires both inkex and gtk libraries.
currently compatible with Inkscape .48.5 running under LINUX
MakeICT foam Cutter github link
Foam Cutter source
I currently have code running in Windows that sends G-Code to the Foam Cutter to cut patterns.
What is needed is an update that inputs a Inkscape SVG file and outputs the appropriate G-Code for the Foam Cutter.
