Facilities April 14, 2026
Many things were accomplished:
  1. Replaced the filters in South Hall HVAC units
  2. Discovered the source of the tapping emanating from Classroom 4 HVAC unit (transmitted sound from gas line shaking against pipe anchor)
  3. Classroom 4 HVAC unit roof top condenser not functioning, diagnosed problem as blown 70+5 mf capacitor. Capacitor removed to be replaced at later date as none is kept in reserve.
  4. Inspected other roof top condenser, functioning fine but needs cleaning and addition of insulation to suction line. Will install when changing capacitor of other unit.
  5. Removed window unit covers inside Classroom 4.
  6. Cleaned out Flame Locker at the end of West Hall and sorted stains, chemicals, oils and paints for disposal / grief area availability. Moved Flame locker to Facilities Garage.
  7. Re-located Grief Area items to dumpster for removal.
  8. Inspected wobbly Hot Metal Shop fan and shut it down. Made the following recommendation to the Board in anticipation of their next meeting April 16th: https://talk.makeict.org/t/agenda-item-for-4-16-2026/34123?u=jpalschauhan
