Event Updates for November 2023
Metalshop Safety Class
Time: Nov 14 07:00 PM - 08:30 PM
Host: Rustin Atkeisson
Register: http://makeict.wildapricot.org/event-5472921
Price: MakeICT Members - $0.00
Price: Non-Members - $20.00
Ages: 16 and up
The Metalshop Safety Class will cover basic safety for working in both the Hot room and Cold room for the Metalshop at MakeICT, as well as some basic expectations. The following tools will be covered :
Pipe bender
Tubing roller
Metal shear
Large and small sheet metal brakes
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Other equipment not listed may require further authorization. This class is required before taking most other metalworking classes or workshops.
Safety glasses are available but we recommend bringing your own if you can.
Time: Nov 20 07:00 PM - 08:30 PM
Register: http://makeict.wildapricot.org/event-5472922
Ages: 16 and up
Pipe bender
Tubing roller
Metal shear
Drill press
Hand grinders
Horizontal band saw
Vertical band saw
Chop Saw
Intro to MIG Welding
Time: Nov 11 12:00 PM - 02:00 PM
Host: John Miranda
Register: http://makeict.wildapricot.org/event-5475341
Price: Non-Members - $25.00
Ages: 16 and up
This class will teach you the basics for Metal Inert Welding (MIG) and set up on the Miller 211 welder. We will cover use of the Hot Area and welding safety. Once you complete this class you will be authorized to use the MIG welders in the metal shop. Long sleeves are recommended. If you have your own welding helmet and gloves you welcome to bring them.
CNC Plasma Cutting Basics W/ Fusion 360
Time: Nov 18 10:30 AM - 12:30 PM
Host: Chris Wirgler
Register: http://makeict.wildapricot.org/event-5477742
Ages: 16 to 120
Learn how to use the CNC plasma machine with fusion 360. We will start with a 2D model and go through the steps to cut it out of a sheet of metal. You will follow along in the classroom to understand the procedure needed to produce the g-code for the Plasma CNC machine. Then, each student will have the opportunity to go through the process on the Plasma CNC machine to do a dry-run cut of the 2D design from class.
Please view the wiki page (https://wiki.makeict.org/wiki/CNC_Plasma_Cutter) as it has the information and procedures we will be following in class. Will move quickly so it’s nice to know beforehand what you’re getting into!
If you intend to follow along using your own computer, you are welcome to bring it. You will need to install and create a Fusion 360 account as well as download and import the tools, templates, and post processor files (all custom for the makeICT machine) from the Wiki before the class.
Wood Lathe Safety Authorization Class
Time: Nov 18 01:00 PM - 03:30 PM
Host: Bill Oden
Register: http://makeict.wildapricot.org/event-5479105
Ages: 16 to 106
Required Authorizations: Woodshop
Plan on about 2.5 hours for the Lathe Safety Authorization Class. Much of the information will be covered quickly, with handouts available. Key pieces of safety will be hands on with examples to hold and examine, and an opportunity for you to use the tools on a workpiece to make some of the things we discuss.
This class wiil be in the 2nd Room of the wood shop.
Safety issues will include:
- Basic Lathe Checks before turning it on.
- PPE for Turning and safe clothing around spinning wood or other material
- An introduction to safe tool usage for Carbide Tools and Traditional Tools with basic information on sharpening.
- Introduction to Mounting Methods for safely attaching the workpiece to the Lathe.
- Wood Selection, considering safety and where the wood is from. We will address the MakeICT Hazardous Material Policy and the
implications for woodturning. This would include working with damaged wood, such as spalting, bark inclusions and worm holes.
Additional PPE considerations and products to address various damaged wood issues.
- We will touch on safety while sanding on the lathe.
- We will touch on safety and choices of finishing products for turned items.
A Test Out Form of this Authorization Class is available.
Class size will vary based on the number of experienced SKW Members available to assist.
Woodshop Safety Authorization is Required
Woodshop Hazardous Materials Authorization is highly recommended.
Laser Cutting Basics
Time: Nov 28 07:00 PM - 09:00 PM
Host: Kim Burton
Register: http://makeict.wildapricot.org/event-5480589
This class will teach participants how to use the 80 watt CO2 laser cutters at MakeICT. We will be using Inkscape and LightBurn software to create and cut a simple project.
Participants will learn the capabilities of the laser cutter, machine and material safety, and operation of the machine in Cartesian (flat) mode. All participants will complete a small project to practice running the machine. Intermediate computer proficiency is recommended. Users should be comfortable with web browsing, Windows file folder navigation, copy and paste shortcut keys, and mouse operation.
Communications Committee Meeting
Time: Nov 15 06:00 PM - 08:00 PM
Host: Aaron Rivers
Price: Non-Members - $0.00
Ages: 1 to 99
Committee meeting for our Communications work.
Time: Nov 27 05:00 PM - 07:00 PM
Host: Aaron Rivers
Register: http://makeict.wildapricot.org/event-5498945
Price: Non-Members - $5.00
Ages: 16 and up
Learn to use exotic materials safely in our shared space. Participants will learn how to clean re-claimed wood, test for lead paint, and adequately clean up after the use of exotic woods. Once authorized, participants will be allowed to use exotic woods in the woodshop at any time. Expect to get dirty. Participants are encouraged to bring respirators if they have one, though dust masks will be provided.
*This CAN be taken before being authorized for the woodshop, though the use of the tools in the space would still require Woodshop Authorization.
The instructor of this class may be slightly late. If so please be patient, if more than 5 minutes have passed or your just very anxious then use his phone number (posted in the woodshop) to call and confirm he is in route.
Time: Nov 29 06:00 PM - 09:00 PM
Host: Aaron Rivers
Register: http://makeict.wildapricot.org/event-5500132
Learn the basics to safely operate the major woodshop tools in this safety class including understanding the limitations of each tool, the forces created when using the tool and how to maintain safe control for improved performance. Tools covered: SawStop table saw, drill press, band saw, router table, jointer, planer, miter saw, oscillating spindle and belt / disk sanders and scroll saw. Expect at least two hours of walkthrough with our tools and equipment, followed by an OPTIONAL hour of hands on practice with the tools aimed at those who have little or no practice with woodworking tools
Prerequisites: Please read the woodshop tool access policy and safety requirements on the wiki page prior to coming to class. Safety Personal Protective Equipment (PPE): • Mandatory: Closed-toed shoes, eye protection, short sleeves • Advisable: Hearing protection
Upon completion of the safety demonstration you can use this woodshop equipment for your projects whenever you work at MakeICT as a member!
Instructor may be slightly late. Please call if you get worried, number is posted in woodshop. Thanks!
