Event notice: Powder Coating Basics (2018 Mar 24 - 3:00 pm)
Event: Powder Coating Basics
Location: MakeICT 1500 E Douglas Ave, Wichita, Kansas 67214
Starting: 2018 Mar 24 - 3:00 pm
Ending: 2018 Mar 24 - 5:00 pm
Register: http://makeict.wildapricot.org/event-2832758
Instructor: Jeremiah Burian
In this class you will learn the correct set up, use, and clean up of the
powder coating equipment, including the powder coating oven.
Each participant will powder coat and cure a metal Kansas keychain that
they will be able to take home with them.
Additional keychain material can be purchased from the instructor during
class for $5 each.
Powder coating is a type of coating that is applied as a free-flowing, dry
powder. The coating is typically applied electrostatically and is then
cured under heat to allow it to flow and form a “skin”. It is usually used
to create a hard finish that is tougher than conventional paint. Powder
coating is mainly used for coating of metals.
The price for this event is $10.00 for MakeICT Members and $15.00 for
Non-Members.
