Event notice: Powder Coating Basics (2018 Aug 06 - 6:00 pm)
Event:
MakeICT 1500 E Douglas Ave, Wichita, Kansas 67214
Starting:
Ending:
2018 Aug 06 - 8:00 pm
Register:
http://makeict.wildapricot.org/event-3016534
Instructor: Paul Maseberg
Each participant will powder coat and cure a metal Kansas keychain that they will be able to take home with them.
Additional keychain material can be purchased from the instructor during class for $5 each.
The price for this event is $10.00 for MakeICT Members and $15.00 for Non-Members.
