Does the space need a larger kiln?
I started building a kiln sometime in the last year or so, but I found a great deal on a larger kiln that needed some electrical work. So I bought that, fixed it, and now I don’t need this partially complete kiln.
If completed, it will have an approximately 17" wide by 9" deep by 13" tall chamber. I’ve pre-wound a coil that will draw around 19amps at 120VAC, which would probably be enough to do wax burnouts. I could wind another coil that would run on 240VAC and would be enough to get to 2000°F or higher.
I also have all the insulating fire brick required, cut to fit ut havent cut the coil groove yet. This brick is pretty easy to work with. It’s hard (will dull tools) but is “soft” enough to cut with hand tools.
Is anyone at the space willing to take this on? If the space doesn’t need it, I’m OK with it going to a member as well.
Filament roll for scale. Also, 9"x 4.5"x 2.5" insulating fire brick for scale.
Thanks!
I would help, to learn how.
