We’re looking to make a drip pan for the Heidelberg letterpress, and we need to have it before setting the press in its permanent home. Here is what it will look like, and the specs:
Also if you would like I can make some kitty litter tubes to place around the outside of the pan just in case.
There may be a sheet big enough in the metalshop to cover that. Or, you might talk to the Tennison brothers sheet metal shop on washington. They donated the material formed the water tray for the CNC Plasma Cutter.
I tried Tennison Brothers, but they want $100 to make one. Glenn checked the metal shop, and there apparently is a sheet that will work, thanks!
$100 sounds about right for time and material.
Was thinking same let me know if we go this route I can chip in a 20$
As can I
