Cutting MDF on the Laser
Looking to make a template for a charcuterie board handle. Will the laser cut 1/2 inch MDF? Thanks.
Yes, but you won’t like the results. The edge will be a burned up, charred mess. It’ll take multiple passes or a very slow feed.
If you are using it as a guide for a router, a 1/4" thick will work fine and is easier to remove, assuming you use double sided tape.
Yeah, I agree with David. If I tried it I would use Luigi and try to get it in one pass, but it will probably be very charred and messy.
Cctfss
