Cnc help
I am cnc certified but I could use a refresher do we just pay to take the course again or is there a condensed version or someone who can go over it with me.
I’m assuming you mean the shop bot since this is in wood. The tormach, plasma table, lasers, 3d printers, etc. are all technically cnc machines, fwiw.
Is there something you are having trouble with? Or are you just not comfortable running it again because it’s been awhile?
It’s been a while I’m ok to design in easel but how to load it into the machine and run safely I don’t remember steps I might be able to make since of my notes once I find them. Lol
This might help. Shopbot - MakeICT Wiki
Make sure to add the extra line to your gcode when you bring it into Linux cnc otherwise it makes lazy corners.
I need to dig up my notes I remember writing it down just don’t rem what it was bet I have an old program I can look at
I was using meshcam for a while and it needed a bunch of code added.
If I remember right prograns generated from easel just needs that code to stop the lazy corners added. “G64 P0.001” near the top.
