Check the doors before you leave!
Reminder: if you are the last person to leave, check the doors to make sure they are closed. If you are going in and out of a door, check that out closed behind you. Some of the doors stick sometimes and need a little nudge to fully close.
If you were the little white car leaving tonight at about 23:30, you failed to check the doors and I found the West door not closed.
Can the door clossers be adjusted to pull a little bit more?
Last time we looked at them they are at maximum.
New door closers might have more power. Facilities can look at them again on Tuesday.
