Can cricut do it better?
People in the vinyl cutting class were curious. After taking a cricut intro course I will say yes, the cricut will probably be better for many of the uses mentioned than the big machines.
We have a cricut maker 3, which means beyond cutting paper and vinyl, it can cut, draw, score, deboss, engrave, and foil a variety of materials, including fabric, leather, wood veneer, and even some metals.
There is a print to cut option for stickers so you can move them from the printer to the cricut to make shaped sticker sheets.
The biggest problem so far is the design space software sucks. Thankfully you can import svgs from things like inkscape or illustrator, but you have to print through the circuit design space. There is some learning curve to getting the design space to do what you want.
So if you want to do smaller sized, detailed projects, you might keep an eye out for more classes.
Thank you Asrah! I have posted another Cricut 101 class on the calendar for Wednesday, August 13 at 6 PM for anyone interested;
Here is the link to the calendar
Where exactly is the cricut?
The Cricut hangs out in room 3 on the left side as you enter on a workbench.
There is another cricut with premade designs in classroom 3 in the back shelves on the far top right, as well as other papercraft equipment.
I believe it is in classroom 3. If you don’t find it there, look in the other classrooms.
On Sat, Aug 2, 2025 at 8:58 PM Josh R Fredrick via MakeICT Forum <noreply@talk.makeict.org> wrote:
| Jrfredrick
August 3 |
Yep. It’s in 3 on the workbench and an older one is in the closet on the top shelf.
