Broken glass watering bulbs
My mom has some broken glass watering bulbs that she wants to re-purpose and has asked if I can fix up the broken ends in some way. Maybe I could cut them off, grind the down, or melt them with a torch? Anyone have any thoughts?
You could try kintsugi if you have all the pieces. If you try lampworking it with flame be careful. Can’t tell how thick it is but just like overheating metal with a torch you can do the same with glass and cause it to pop.
I see a light fixture. Clean up the ends would be the hard part. Maybe dremel/diamond wheel/tile saw? After that, throw in some LEDs and mount to a base and plug it in!
You might be able to score around the piece at the lowest point of the break with a glass cutter - then use a pair of grozier Pliers to nip that “extra” away. Doubt the glass grinder at the space would be much help as the bulb would interfere with contact but you could wet sand to clean up the edge once the break cleaned up. If you do use a dremel to grind, be sure to keep the glass cool (wet). Wear safety glasses in case of flying shards. Things go wrong in a hurry sometimes.
Torch work won’t always work well with certain types of glass. If it were me I’d lightly sand / grind the sharp ends down a bit, then replace the broken off bits with air dry clay or putty resin.
They would make cool lamps though. I’ve done mixed media with glass and bondo. That was back in the 90s though.
