FYI: I just burned a new screen, went to wash it out, and the nozzle on the power washer is spraying everywhere. I’ll mop up, but it definitely needs replaced. Do we have any replacement nozzles anywhere?
Edit: Never mind, the nozzle isn’t the problem. The coupling itself is broken.
Probably a dumb question, but did you have the pump turned on? I noticed when I used it on Sunday that its sprayed out of the joint in the coupling if the pump was off, but it worked fine when the pump was running.
