Bisque unloaded 2/19
Was this everything on the bisque shelves I can’t seem to locate My pieces
I am not the one who loaded it- but most likely they were unable to fit everything in the load. When we fill a kiln we fit everything in it that we can from the shelf near that kiln. But often we can’t get it all in. We try hard to get missed pieces into the next load. If your work was on the bisque firing shelves and was completely dry, it will most likely make it into the next firing.
Also, If a piece is still wet or is thick, the operator will wait to fire it until it is safely dry before bisque firing. Moisture in clay can cause the piece to explode in the kiln.
But most likely, the kiln just was too full to fit everything in.
