Has anyone tried a thin aluminum on the laser cutters? I don’t plan on anything thick nothing bigger than a 1mm!
The laser cutters will not cut metal.
I have seen people try to etch aluminum blocks and even with the power cranked up it doesn’t even leave a mark ![]()
You’re welcome to try! It’s not forbidden, just not productive.
When she says crank the power up, do stay within the limits given during the laser machine authorizations. Do not set it to 100%.
There’s a chance that attempting this will damage the lens or the lens coating. The energy will be reflected.
There is a way to safely engrave metal with the laser, but it takes a special spray paint that’s ridiculously expensive.
Our co2 lasers will not cut any metal ! And polished metal can reflect beam back into laser causing expensive damage ! A 150 watt co2 laser with oxygen attachment will cut steel and stainless steel but only up to 18 gage i have done this, it will not cut brass, copper, or aluminum ! The new enclosed gantry style Diode lasers 40 to 70 watts will etch, engrave, leave deep marks and cut most metals, but not super fast for any production ! Fiber lasers are a better choice but unless fully enclosed are a danger to everyone who enters the room !
