Air tool refreshing
Heads up,
Just went through the air tools. All of them were checked and oiled including the one that no longer has the INOP tape on it. All of them are working with the exception of the grizzly air nibbler (it need a new tooth).
If it doesn’t seem like the die grinders are spinning fast enough, there is an adjustment screw on the opposite side of the trigger that can be turned to either allow more or less air through to change the speed of the grinder.
If something else doesn’t seem to work or you’re not sure how to use the tool, let me know.
thank you.
Also, there is a fresh hose on the sand blaster.
I haven’t tested it out, but that should at least take care of one issue. There is also a ceramic nozzle inside the gun that may have gotten worn out.
If someone uses the sandblaster in the next couple days, please let me know how it works out.
Wallis tested the sandblaster last evening. It is working!!! Thank you Rustin!!!
