I’m trying to help a coworker cut out words in 1/4" wood and the pine I used burned a 1/4" wide line rather than a clean cut. Would it work better if I used plywood? Or maybe multiple passes with a faster cutting speed?
I used the suggested settings of 50% power 15mm/min cutting speed
Also I saw there was a class for this topic last month, does anyone from that class have any suggestions?
It’s hard to tell from the picture but it cut all the way through, and the back side is a few mm wider than the front side. I remember autofocusing before this run.
I forgot to say that I got it to work properly, I had to increase the speed 5x to 100mm/min. I’m guessing the suggested speed of 20 is for higher density wood.
