13mm reamer?
Hi all, metric machine shop tool are still fairly uncommon but does anyone know if we have a 13mm reamer anywhere or does anyone have one I can borrow?
I need to remove some excess powder coat out of an existing 13mm bore so duration of usage wear will be very minimal.
Thanks,
Aaron
I don’t know of any reams at makeict. I know I personally have a few reams, but unfortunately no 13mm.
I’ve always gone to the yard with a pair of calipers and found what I’ve needed.
They’re all mixed together in a tub in the drill bit area, so expect to spend some time digging through them.
Hope that helps!
Thanks Joe. After I got home I did see that I can get one on Amazon for about $10 shipped. Not the preferred route but it’s an option. I might try the Yard but I’d be surprised if I find anything close enough to .511 or so. Reamers a thou (or few) under common imperial sizes aren’t usually too hard to find but I doubt finding any slightly under 33/64 would be likely.
Aaron
