Wood Shop Sawdust
Does the sawdust get thrown out or saved for someone else? I would like to have it if I could.
Unless someone is purposefully collecting sawdust (like a bunch of cedar chips off the planer) in specific instances, the sawdust if emptied directly into the dumpster.
I have no problem with you taking the sawdust that we generate. However, please be advised that the composition of that dust cannot be ascertained with any accuracy. It may gontain glues, plastics, composites, and toxic wood species that are unfit for pet bedding or garden use.
Thanks for asking!
Thank you, it is for a compost toilet so anything will be fine.
ยทยทยท
[mailto:noreply=talk.makeict.org@mg.makeict.org] On Behalf Of Aaron Rivers
via MakeICT Forum
Sent: Monday, November 21, 2022 11:00 AM
To: 56robles@cox.net
Subject: [MakeICT] Wood Shop Sawdust
<https://talk.makeict.org/user_avatar/talk.makeict.org/squarenuts/45/3938_2.
https://talk.makeict.org/u/squarenuts squarenuts MakeICT Board Member,
Woodshop Area Lead
November 21
into the dumpster.
Thanks for asking!
https://talk.makeict.org/t/wood-shop-sawdust/18977/2 Visit Topic or reply
to this email to respond.
To unsubscribe from these emails,
<MakeICT
988d0308e0a1f13f132bdc4410610ad5> click here.
Curious Question. Compost Piles work with a balance of Greens and Browns. Fresh Produce Trimmings are typically in the range of 1:10. Newsprint is 1:500 and Sawdust is around 1:800. The pile works best with a overall 1:40 or 1-60 mix. No pile is perfect. You still need to add water (Usually rain) and let it generate heat. I have a large compost pile and too much sawdust will require some Milorganite (1:1) to get it going.
TIA John
So my curious question is what is the composting toilet doing that my large pile is not?
One answer is that urine is extremely high in nitrogen, so carbon (sawdust) is used for balance.
Solid waste is usually already pretty balanced, but then sawdust is added to help control odor and compaction.
Green vs. brown is just a mnemonic for nitrogen vs. carbon. There are also wet/dry balance (as you mentioned) and aerobic vs. anaerobic decomposition considerations among others.
Mike,
Thanks for the info, You did well. I used the green/brown to follow KISS.
Human waste disposal instead of using the a sewer system. Not intended for
gardens unless you wait 2 years.
ยทยทยท
[mailto:noreply=talk.makeict.org@mg.makeict.org] On Behalf Of John Nicholas
via MakeICT Forum
Sent: Monday, November 21, 2022 11:27 PM
https://talk.makeict.org/user_avatar/talk.makeict.org/stnick/45/6479_2.png
https://talk.makeict.org/u/stnick stnick Classroom Management
November 22
TIA John
pile is not?
https://talk.makeict.org/t/wood-shop-sawdust/18977/4 Visit Topic or reply
<MakeICT
2e661162e252b123f5d2f00b26f38168> click here.
