I’m curious what projects people have going on around the space right now. I’ve got a few things in the works myself. What’s on your bench or in your sketchbook? Always looking for inspiration.
I am working on making a program for kids… so I got a balloon powered car in the works currently… next up is straw bridges…
I just took the laser cutting class and have been learning to 3D print. I’m trying to make some simple projects, like customizing a badge holder print. I’d like to make a little book nook scene using projects from lots of different areas at the space.
I’ve been figuring out how to make lumber from recycled plastic. I’ve figured out how to give the material an artisanal granite look, but the strength isn’t near what it should be (40% of spec for brand new PETG from my testing)
I tested a 1in thick 3 1/2in wide sample that was a bit over 18in in length, leaving 12in unsupported as a cantilever beam for testing. It failed after applying about 200ft of force. Failure seems to be attributed to flexural stress (bending stress instead of shear stress). There’s a 30% knock down in strength due to it being recycled PETG, and another knock down for porosity (air bubbles) but not sure if i’ve captured what all would account for a decrease in strength.
There was a local company called iirc millennium plastic wood that made products from mixed recycled plastic. Their process was an augur feeding through a metal pipe with a tube heater through extrusion dies. Mostly they had feedstock that was shredded and also mistinted and end of batch plastic pellets that were virgin thermoplastic. They found that 1X lumber was unusable and mostly made 2X6 and up through at least 6X8 and they also had a process for 8X8X16 hollow blocks. I’ve got a couple of smaller samples and a couple of large timbers they made. They went out of business after getting a contract from the Kansas Department of Transportation to build a highway rest stop restroom using the hollow blocks for walls and the structural strength wasn’t sufficient probably because of the difficulty of adhering the block construction together.
